Vespa 300 GTS HPE, Vespa 300 GTS
Hello everyone, I'm quite a mechanic and have everything I need to work on my vespa. I've searched the forum but haven't found anything on the subject. I bought a vespa 300 gts 2013 without keys and a lot of rust, changed the lock and coded the engine control unit to the new keys and welded the rust holes with tig. I adjusted the valve clearance and checked the timing.
Everything looked good and it starts immediately and runs well at idle. But when I accelerate it dies immediately. The fuel pump works and has pressure on it, the nozzle does not spray cleanly, I cleaned with ultrashall, but unfortunately the situation has not changed, I also changed the spark plug without success. With the Digitek diagnostic device I can see that from 4 degrees throttle / 1800 rpm the engine stalls. Every Parameter looks good and no engine light and no dtc is stored. I think the air/petrol mixture is not right, there is no false air, I checked it by spraying brake cleaner on the hoses when the engine was cold. Does someone know more?
are you sure coded the keys correctly? iirc when the ecu has no keys coded (eg reset or brand new) then it can't run above idle.
It would just get rev-limited to 2000, it wouldn't stall out.
that's what I though, but interesting coincidence that they had reprogrammed the keys (and I cna't think of another reason)
pondering more ...
exhaust blocked?
is it instant cut as though by the ecu or is it that it struggles and dies?
SteelBytes wrote:
pondering more ...
exhaust blocked?
Good thought - and we've had a couple of cat 'extrusions' reported recently. Could easily happen, especially to a rusty neglected bike!
What about a clogged air filter? Enough air might get past for idle, but when throttle is demanded, the extra squirt of fuel given for acceleration might get the engine to stumble and die (but that's just speculation).
Oh - and is "ultrashall" an ultrasonic cleaner?
Good evening,
Thanks for the hint, I had reset the engine control unit and deleted the keys, but did not create new keys, is really strange the behavior of the immobilizer, would have preferred that it does not start and stores an error code in the memory, have I overlooked something or is this mentioned in the workshop manual?
Or do you just need to know that?
With the Digitek diagnostic device I can only read the immobilizer and query the status but not learn the keys, I had to use the AWS Next in combination with the Xhorse Key Programmer to read the ID.
Thanks again! Saved me a lot of headaches and time! Facepalm emoticon
Yes it's ultrasonic and not ultrashall, ultrashall is in german 😅
[ Time: 0.0073s ][ Queries: 3 (0.0017s) ][ live ][ 313 ][ ThingOne ]
