SIP #86131120
Looking for you feedback on using this wiring loom when running a VAPE ignition for full DC in a USA market P200e. From the get go, looks like no neutral safety switch or front brake circuit.
Will the ignition lock (I) work just the same on our headset switches?
Why would they run a 1960's switch (E)?
No turn signal light circuit for indicators on top of the headset.
makes me want to install a stock P200e wiring harness (either single yellow or double yellow) and just use a universal 12v rectifier.
https://www.sip-scootershop.com/download/article/1/pdf/b3ecf158-5e41-4359-83b7-669468a68800/86131120+-+VAPE.pdf?contentType=application-pdf
