Parting out
1981 Vespa p200e
No Motor
Original Parts
Frame with keyed lock - titled $650
Gas Tank with new
Fuel tap - clean and operational - $150
Side cowls - $500
Fork with hub - $200
Front Fender - $45
Headset - $200
Indicator Lights - high/low, Turn Signal - $50
Speedo - $200
Glovebox - $75
Horncast with badges - $50
Horn Bracket - $45
12v battery Horn - $55
Two rims with tubes and tires - $40
Fuel tap conversion rod and plate - $25
Headlight lens, glass, bulb holder and bulb - $55
Horn, high/low beam switch - $50
Turn signal, kill switch - $50
Ignition key switch -
$50
Gear select inner cables
Glovebox lock with matching seat lock - $40
sealed battery - $25
spare tire cover - $25
Rear bumper - $25
Seat with keyed lock - $150
Siem turn signals - $25 each
No Motor
