@gickspeed avatar
@gickspeed avatar
Looking at building an engine using new SIP cases for a SF 125 (VMA). Going to use a VMC 135 cylinder.
going to to run a 24mm PHBL, Rotary valve
would like to use the EVO cases that have 3-hole manifold input. It appears Polini does not off a 3-hole manifold to fit both a 24mm carb and the older chassis', ET3 etc. I really do not want to cut the frame. https://www.sip-scootershop.com/en/product/crankcase-sip-evo_24301000?usrc=sip%20crankcase%202-hole
Polini does offer a 2-hole manifold for the 2-hole SIP cases for 24mm carb. There would be machine work i would have to do to get the VMC cylinder to fit; namely, removing the dust cover for flywheel. https://www.sip-scootershop.com/en/product/crankcase-sip_24303000?usrc=sip%20crankcase%202-hole
anyone played or heard anything good with this conversion piece? your thoughts? https://www.scooter-center.com/en/intake-manifold-inkl.-carb-rubber-strohspeed-for-carburettor-dellorto-phbl22/24/26-conversion-of-clamp-to-rubber-compound-cs-30mm-28-5mm-30mm-3332351kt?number=3332351KT
perhaps something else in the market i am not seeing?
i kinda hate the idea of adding one more area for an air leak.
@exmayor avatar
64 V90 survivor '65 Allstate survivor. '75 V90 SOLD. '77 P200 SOLD
@exmayor avatar
Jon
I had that same issue with the motor you built for the green SF.
Ultimately had to trim the opening after it was painted.
Hated doing it but couldn't find another solution.
The only other potential way is to fabricate a flange, have some 24mm ID tubing bent and use the rubber mounted.
There might be a market for these conversion intakes to fit PHBL 24-30 to early V smallies using 3 stud rotary intake cases.
@mjrally avatar
73 & 74 Rally, 76 ET3, 80 P200, 61 Ser 2, 65 Silver Special,, 2015 HD Road Glide Special
@mjrally avatar
I know you said rotary build, but could you remove the reed from this one? Or just leave it in?
https://www.sip-scootershop.com/en/product/intake-manifold-polini-by-sip_21501151?usrc=Polini%20reed%20manifold
@safis avatar
@safis avatar
I did this. Used the 30mm manifold and machined / welded a new end piece…
https://www.sip-scootershop.com/en/product/intake-manifold-polini-phbh-28-30-tmx-27-30-pwk-28-30_21504350
@gickspeed avatar
@gickspeed avatar
that's good. a little lathe work and TIG weld it. was hoping i have overlooked an off-the-shelf item, but this may have to work.
@safis avatar
@safis avatar
Nothing ready-made for 3 hole cases on SF, that's why I went that route. Only difference I used a CP24…
@gickspeed avatar
@gickspeed avatar
it's so crazy, you can buy 3-hole 16, 19, and 28-32. for whatever reason, nothing in the 24 range.
@108 avatar
V range 50s
@108 avatar
V range 50s
The only ones I see are for PK, not sure if there's a figment issue with the frame.
@gickspeed avatar
@gickspeed avatar
Yes. Fitment issue.
[ Time: 0.0131s ][ Queries: 4 (0.0022s) ][ live ][ 334 ][ ThingOne ]
