@wolfgang avatar
Vespa LX 125 (2005)
@wolfgang avatar
Vespa LX 125 (2005)
On a recent trip my Vespa LX 125 (2005) started coughing and spluttering. When stopped it was very difficult to start again and would barely run only on full throttle. I put this down to having filled with old fuel. I also had issues with a petrol strimmer that used the same. The strimmer is working fine again having drained the fuel, cleaned the carb and used new fuel.
On the Vespa I have also drained the fuel, changed the fuel tap and filter and refilled with new fuel but still runs rough. What else can I do? Clean the carb, replace parts in the carb? Is there a carb repair kit available? Grateful for any suggestions.
@abner_bjorn avatar
2007 GT200,2008 Yamaha C3,2009 BV250, 2013 GTS300 Super
@abner_bjorn avatar
Your scooter is 19 years old. Check for air leaks. Replace all the fuel and vacuum lines if they are original. Be sure you don't have a crack in the intake manifold. Do this and see how it runs before you yank the carb.
@wolfgang avatar
Vespa LX 125 (2005)
@wolfgang avatar
Vespa LX 125 (2005)
Thanks.OK will do. Just seems strange that other engines using same fuel had issues. Is there a problem with dismantling carb?
No.
It's the reassembly that causes problems.
@wolfgang avatar
Vespa LX 125 (2005)
@wolfgang avatar
Vespa LX 125 (2005)
OK thanks - can you point me to any guides, videos that would help in case I have to do it. Might try adjusting mixture before that. Will check everything else first.
@tripo avatar
2016 GTS 300 Settantesimo Grigio Pulsar
@tripo avatar
znomit wrote:
No.
ROFL emoticon Clap emoticon
[ Time: 0.0087s ][ Queries: 3 (0.0030s) ][ live ][ 334 ][ ThingOne ]
