chandlerman wrote:
We can talk you through it, but it might take a while and you're going to learn a LOT along the way. If you're good with that program, then let's get started
First off, which of the following did you measure/test, what was the measurement, and how'd you measure it?
- Port timings
-- If you installed base or head spacers, what'd you install?
- Squish
- Ignition Timing
- Jetting
- Cold Compression
- Pressure Test
As to parts..you said it's a ScootRedacted, I assume their knockoff of the JL Lefthand pipe?
Is the crank 57 or 60mm?
What reeds? Just a regular RD-350 or something more aggressive, like Tassarini VForce4's?
What sort of porting did you do? Nothing? Just relocating/matching the Malossi? Something more?
Did you open up the intake itself?
Which Malossi head?
I assume you're still on stock gearing.
You should go ahead and get a cheap CHT and Tach. They'll come in handy once you start dialing in the carb and potentially save you from some expensive mistakes.
You're not going for an exotic build, but you are going to something that's esy to get very wrong, very fast.
And I agree with those who suggest a box exhaust. I'd grab a SIP Road 3.1. I have a similar setup on my P200 motor and it pairs nicely with the Malossi for limiting noise/discomfort while still delivering solid performance.
Thanks Chandlerman... I really appreciate the thoughtful post and effort. If I'm honest, I really don't think I have it in me to go that deep. I'm very much not a gear head, although I do like to have a crack at things. I'm also 52 and I hate to say it, but whatever you teach me I would struggle to grasp (in a meaningful way lol). My brainbox just doesn't absorb information like it used to.
The kit, pipe and carb were all done prior to me getting the scooter- sorry, my original post's wording was a bit misleading- I mentioned it further down the thread. I should go edit the OP. All I did was reed block and full circle crank. I opened up the intake and that's it. I really don't think my machinist guy touched the pad... but it was 20 years ago.
Pipe... yeah mine looks like the JL one.
Which Malossi head... I don't know, it was done before I got the bike.
Reed block is Malossi.
Gearing... I did find out recently that I have an EFL selector box on a PX old transmission so maybe someone in the past ticked around with the gears?
I think I'm going to start with the jetting and ignition timing for this season (it's not very long up here and I only just got on the road in the last week or so) with a view to putting my old crank back in in the off-season and consider the pipe you suggested.
