Riding normal, out of nowhere- all power loss, like if you turned off the key.
no bumps or potholes to jiggle any loose wiring.
It just cuts out.
coast to a stop, key still on, squeeze brake, restart the scoot. it keeps doing this all the time now.
Scoot runs perfect until it just dies.
It does not have a sidestand kill switch.
parts changed or inspected:
new battery
new injector
power relay block
all fuses are good.
new spark plug-- cap is on tight.
while its running normal, I jiggle the key and push all the buttons. try to recreate it---nope, nothing makes it die.
but it just does it on its own, no warning.
im thinking a bad coil or coil to plug wire. sporatic continuity ????
what do you guys think? Help
⚠️ Last edited by Donttellmywife on UTC; edited 1 time
