Tbrduc wrote:
Well, first, the lack of punctuation makes this tough to read.😉
But, can you access the fuel tank float? Open the speedo again. Remove the float and manually make the needle move.
I just did that with a Non-Vespa.. to test the various elec bits.
Fuel not needed. Turn on the key..gently raise the float… see how the needle responds.
Just a thought.
Access to the float is the stumbling block.
I expect there's a bad connection to the headset from the sender.
