Made a great deal on a 65 VNB6t.
What is the necessity of that shit ?!
It has been a pain to remove, windscreen glue is hard to cut when you have poor access
I scrapped the paint of the floorboard, not the best, a bit of corrosion
The right floor board is in a very bad condition, the scoot had an accident and was poorly repaired, I can't find the pictures I took from now, I will post them later.
The Vespa is in ok condition, the fuel tank was full of rust... I took the carb off in order to give it a bath into the ultrasonic cleaner, replaced all gaskets, used a separate fuel tank to test, the engine easily started ! Yeah
I think I'm going to replace the leg shield + floor, in 1 piece.
I need to find the weld spots and cut into.
I will also replace the horn cover, but how is fixed onto the leg shield ? I cant see any signs of spot welds, is it glued ?
