Piaggio 530HPE
Piaggio 530HPE
I would like to replace the horn on my 530 HPE, I can f***t louder than the existing one. The problem is that I doubt that anything useful will fit in the original location due to body panels shrouding it. Has anyone fitted a replacement and where did they mount it?
2015 MP3 500 ie Business
Maybe something like this?
?si=2JwfvhO60o92G7Ou
Piaggio 530HPE
Piaggio 530HPE
The horn looks good, but as Robot found, it is too thick to go in the original position on either the scooter or the mp3
mp3 500
mp3 500
I added a older gold wing horn to my 2021 mp3 500. It was a job but I got done. Prior at speed and with hearing protection and a helmet I could not hear the stock horn while riding, now no problem, and it sounds much better. (to me at least) Has a more car like sound ( 103 db's) not the 'roadrunner beep beep'.
Horn
Horn
Piaggio 530HPE
Piaggio 530HPE
Thanks for the pics, I cant really tell where exactly it is mounted, can I have a bit more info please? Where did you run the wiring from the original location?
mp3 500
mp3 500
I removed the bottom center covering and fabricated a bracket out of aluminum
and used one of the frame bolts. It's a simple flat piece bent via vise and hammer to fit , just something I had laying around, and yes I used the stock horn wires, I didn't cut the ends in case I wanted to put it back to stock. just used posi-taps. I expect one could use scotch locks I never cared for them but they would work. The horn I got on ebay. Left the stock horn in place.
horn2
horn2
Piaggio 530HPE
Piaggio 530HPE
Thanks, it all makes sense now
[ Time: 0.0088s ][ Queries: 4 (0.0022s) ][ live ][ 343 ][ ThingOne ]
