Piaggio Fly 150
Piaggio Fly 150
I have a 2009 Piaggio Fly 150 with only 264 original miles on it. It was always stored in a garage. I recently changed the oil, and it was starting and running but then stopped starting. It cranks but will not turn over. After replacing the carburetor with a new identical OEM carb - it still does the same thing. There is spark at the spark plug, gas does appear to be entering the carb and even with the air filter removed, it still just cranks. I've tried holding both and then each individual brake lever and also switched the kill switch on and off several times - still nothing. I thought perhaps the fuel mixture on the new carb may have to be adjusted - but wouldn't the engine still start. I didn't move it yet. I checked and rechecked the new carb installation and everything seems correct. Any guidance would be very greatly appreciated. Thank you.
you have a 15 yr old scoot with 260 miles on it. I recommend you take it to a professional and let them service it and get it sorted out.
Piaggio Fly 150
Piaggio Fly 150
Thats a fine idea but there are none within a reasonable travel distance from me.
Fresh petrol?
@greasy125 avatar
@greasy125 avatar
did you drain and flush the tank? if you're running old gas thru there it's likely clogged the new carb as well.
put the air filter back on, or since the the OE air filter has likely long since turned to dust, a new air filter in there. the CV carb requires a tuned intake tract to operate properly. it won't hardly idle, let alone run with it disconnected.
there's an absolute ton of other things that will need addressing, but let's start with getting it going first.
Piaggio Fly 150
Piaggio Fly 150
Thank you. The gas was new but I did not drain the tank. What and where is the tuned intake tract?
Was there enough time in there for a critter to make its home in your exhaust?
Has the vacuum line perished?
Piaggio Fly 150
Piaggio Fly 150
How should the vacuum line run and how can I test it?
Piaggio Fly 150
Piaggio Fly 150
Im going to replace the starter motor and bendix both of which I will receive today. Any guidance, pointers or secrets on how to do this would be greatly appreciated. Thanks all again.
What do you mean by this?
what's reasonable?
5 miles
50 miles
100 miles
thank you. those statements confuse me as well
To me cranking it is turning it over
now if its not firing and or spitting and sputtering and coughing that's another issue.
so why would somebody replace a part that is doing its job and making the engine turn over is beyond me,
[ Time: 0.0094s ][ Queries: 3 (0.0036s) ][ live ][ 313 ][ ThingOne ]
