Being a habitual user of cheap foam earplugs whenever I ride, I occasionally (roughly 2 out of 5 'applications') will experience a problematic earplug extraction episode that requires the use of a specialized tool to rectify, almost always in my left ear for some reason.
Immediately after the arrival at my destination, if the offending foam plug resists my efforts at removing it digitally, I will resort to mechanical means and retrieve my special tool from the dark abyss of my well-worn Triumph backpack and apply it as-needed in order to remove the wedged foam ear plug and restore my normal hearing.
Surprisingly perhaps, most of us already possess this special foam earplug retrieval tool, and if not, one can be sourced from almost any neighborhood hardware store for several dollars, Euros, shekels, or whatever currency is appropriate for one's area.
Of course, it goes without saying (but I'll say it anyway), that using tools of any sort for the retrieval of foreign objects from one's body should always be done with caution and careful consideration to avoid unnecessary discomfort or even injury.
You're welcome!
