Starts up easily. Goes to idle without problem. Can drive it for about 10 minutes, then whenever goes to idle, it will stall. Every stop sign/light, it stalls.
I removed the air filter, doesn't look dirty.
I removed the carb, cleaned the idle jet, the main jet, and the bowl. Noticed that the accelerator pump moves up and down, but doesn't really squirt fluid. Also noticed that when the carb is disconnected from fuel line, fuel flows out of the fuel line without stopping. Also noticed that when engine is running, if manually depress accelerator pump lever, engine bogs.
I have ordered new idle and main jets. I have ordered new air filter. I have ordered new petcock(vacuum model).
Where is the fuel filter? Is there one? I have an inline fuel filter and hose i can install.
Does anyone have any ideas other than what I have come up with?
⚠️ Last edited by Landy89 on UTC; edited 2 times
