After more than two years absence, the Malossi V4 Head for the Vespa GT, GTS and GTV is back. It also fits on the BVs with similar displacement. If you like your older GTS, or just don't like or want to buy one of the new ones, this is how you can get about the same performance out of your old Vespa as the HPE puts out.
Over the years, the Malossi V4 head has proven to be a very reliable replacement for the stock Piaggio head. Many of them have been fitted to Scooter Cannonball bikes that successfully completed the event.
Here's a bunch of stuff off the Malossi site, including graphs and pictures.
4STROKE V4 HEAD
Monumental Achievement - Malossi
Soaring scooter performance with a power increase of 15%-25%
The first head for all Piaggio scooters that have a 4-stroke, liquid cooled engine with the following displacements: 125*cc, 180*cc, 200 cc, 250 cc, 300 cc. With more than seventy applications and designed and developed to deliver great excitement, insures this head a brilliant future.
Technical Specifications:
Head made of gravity-fed cast aluminium alloy, tempered and sandblasted, machined within thousandth (mm) tolerances utilizing super precise work cells.
Valve guides designed with new profile, made using a powdered metal sintering process (steel, phosphorous, carbon, copper and manganese).
Valve seats made of cobalt-molybdenum steel alloy characterised by copper infiltration and a special heat/chemical treatment. Increased intake valve - ø 25 mm, made of a special steel alloy and a special heat/chemical treatment.
Increased exhaust valve - ø 22.2 mm and made of Nimonich 80 material (Nickel, Chromium, Titanium, and Aluminium alloy).
Exhaust and Intake valve springs made of Si-Cr oil-tempered and annealed steel, designed to operate optimally under increased loads due to increased engine power.
* This new head was developed to be used exclusively with Malossi cylinders for the displacements 125 cc ? 180 cc, while with all other displacements, this new head can be used with the original cylinders. The head is pre-assembled and ready for installation.
