Petrus wrote:
Any ideas on WHÝ the smart people at Piaggio designed the heart shaped ´roof´ space above the jets? I mean they inténded it to be there like that.
Second question: A more spacious filter cover makes sense so I am fitting one but I am wondering if there is experience with that here and if any effect was noticed.
Third one: The T5, even though only 125 cc has a slightly higher, better flowing airfilter so surely it will be beneficial on the 200 too. Anyone tried this?
The heart definitely acts as an air brake. It's also an air flow stabilizer (AC's not directly exposed to air flow to the bore/changes in air pressure).
Bigger air box cover helps for a more harmonious air flow. It will not give you more power but it won't hurt. Generally they're used with a venturi to provide more space above them, but I like how it feels/sounds with a filter.
Many have tried the T5 filter. It isn't designed for that carb. Barely open throttle becomes difficult to sort out (bore too tall).
Be careful adding complications to your bike for minimal power gains.
Jetting is complicated business! Even drilling the filter can do damage if you don't jet to compensate.
In my anecdotal experiences, reducing the air corrector by at least 10 is enough but your bike is different.
