Piaggio MP3 500
Piaggio MP3 500
I have changed the broken stator in my MP3 500 (2012) but after reassembling everything the engine doesn't start. For me it seems like there is no spark on the spark plugs.
Does anyone have an idea where the problem can be?
MP3 500 HPE 2019
MP3 500 HPE 2019
First guess have you checked the fuses, also if red light is on could be immobiliser
Piaggio MP3 500
Piaggio MP3 500
Yes, I've ckecked all the fuses (they're all good) and also the red light is not on.
the dreaded hidden 30 amp fuse? and not the spare that's attached to it.
Piaggio MP3 500
Piaggio MP3 500
Where can I find that one?
MP3 500 HPE 2019
MP3 500 HPE 2019
Piaggio MP3 500
Piaggio MP3 500
I foung the fuse but it's completely OK, so the problem must be somewhere else...
MP3 500 HPE 2019
MP3 500 HPE 2019
Some good places to look and test in thread below
MP3 500 no fuel and no spark questions
@jah avatar
Piaggio MP3 250'2007
@jah avatar
Could be a problem with ignition (phase) sensor. Quite unsure what's the English for it, but that thing is located on stator and gets a signal from magnet (rotor) for spark timing.
The black thing center-top. Also its connector is black.
Piaggio MP3 500
Piaggio MP3 500
Don't you know what exactly can be the problem regarding the ignition sensor? The whole stator is new so I suppose that the sensor should be OK.
MP3 500 HPE 2019
MP3 500 HPE 2019
Is engine turning over but not starting, if yes check fuel is arriving
You say "seems like there's no spark" - well, is there or isn't there spark?
And as above - is there fuel being squirted out of the injector?
@jah avatar
@jah avatar
The sensor might be misaligned, damaged, rotated or so
The cable could be damaged
The connector could be disconnected or damaged
So check everything you can regarding that sensor. And yes, try to find out whether you have spark or not.
@dariusz avatar
2007 MP3 250ie / 2022 MP3 500HPE SA
@dariusz avatar
This is a very valid comment. If when installing the stator with the incorporated crankshaft sensor it was not in the exact place or had some damage/disconnected, it could explain the symptoms very well.
Piaggio MP3 500
Piaggio MP3 500
We have checked everything with a friend who has better knowledge about the motorcycles than me. We found out that there is no spark and also there is a problem with fuel injection. When we had injector out and were pressing the starter button, it injected the fuel only 2-3 times and not more.
[ Time: 0.0189s ][ Queries: 6 (0.0051s) ][ live ][ 334 ][ ThingOne ]
