GickSpeed wrote:
"NOTE: The exhaust was designed explicitly for the PX models. On older vehicles, which were built before the PX series, it is possible that the stop plate of the main stand touches the manifold. Either modify it accordingly or check if a too long distance piece was mounted between shock absorber and frame (Sprint / Rally = 26mm). On the 125-150 cc engines of the Sprint, VBB etc. the engine block should also be provided with a hole for a through exhaust screw. Otherwise the exhaust will only hang on the rear bracket. This is not sufficient in the long run, because it can break off."
Thanks. Please excuse me for starting a new thread for this and should have stuck with my "NOISE" thread.
The ride height at the rear is fine right now so I don't think shortening the shock is the answer but I might see how that works.
I figured it would fit because of the LML in this Motovespa 150S : " Polini Stock Type Replacement Exhaust for Vespa PX, Genuine Stella and LML Star 2-Stroke Scooters." Nobody mentioned this potential problem.
