I'm Back! I haven't been able to test-ride it yet...! I am dumbfounded by the
carb flooding. The carb has been taken apart and cleaned.
The timing was done by a static light and seems right. Firing at 24 degrees BTDC.
Everything ran 100% on the bench engine test stand and once in the frame it became very hard to start and when it did the idle was not smooth and bogged down at acceleration. Cleaned all the jets and the float moves properly. The pilot jet can be a 1/4 open or per spec 1.5 with no noticeable change. The throttle screw is down and isn't making any changes to the idle.
Maybe I need to go back and redo the timing.
