Vespa ET4
Vespa ET4
Thx to all who respond. This site is great for my newest Vespa obsession! Ridden 450 miles on '01 ET4. 3050 miles on scooter. Since I bought it, upgraded to Michelin City Grip 2 tires, Bitubo shocks (front/rear), replaced air filter, intake manifold and all fluids. Adjusted idle and it runs great. My first Q is fly screens? Worth the investment? Scooterwest (San Diego) has Cuppini small (13" tall x 17" wide). I like the look without one but do others think it's a game changer in sunny weather? ET4 tops out at 50 mph since I weight 240. 2nd Q is replacing carburetor and brakes? Vespa said aftermarket carburetor (Keihin) at next service will help it run better and brakes at 50% wear but noticed squeak on front wheel. Any feedback welcomed.
Front brake pads - should have at least 1mm, else change them. I am using Malossi pads.
Windscreen - i have a tall one, because of cold. Likely not an issue for you. Wear a full visor helmet, then you will have no issues of any kind - bugs or otherwise. Even at 50mph, the wind force on your body isn't too excessive. If you find wind force excessive, then get a small deflector screen. Full-face helmet with full visor is a must though - wouldn't wear anything else, not safe.
Drive belt and variator rollers should be changed soon. You can change roller weights to get more acceleration or more top speed (trade off).
@rickster333 avatar
2001 ET4 "Mona"
@rickster333 avatar
2001 ET4 "Mona"
I weigh a bit more than you. I routinely hit high 50's (by GPS). The Speedo shows low sixties to about 65mph. I don't think the GPS is lying.
I think a valve adjustment might help. It's pretty easy on an ET4.
I use a windshield: too many bugs where I ride. I'd rather they splat on the shield instead of my face.
Sounds like you're having fun, so you've already won!
Vespa ET2, LX50 2T
Vespa ET2, LX50 2T
The fly screen options for an ET are limited.
I fitted one from a Vespa S part number 655523.
Obviously it's not a close seal round the headlight but it does the job and I prefer the look of it to the ET options.
I found someone in the U.K. selling new old stock for £75.
1st pic off the internet as I didn't have one from the front of it fitted to mine. Fits without any modification.
The other nice upgrade I did was to fit LX mirrors. It's not just cosmetic, they work better. Primavera, GT mirrors work also.
One fits straight on, the other I bought an adaptor from beedspeed in the U.K.
[ Time: 0.0095s ][ Queries: 4 (0.0028s) ][ live ][ 343 ][ ThingOne ]
