@lars_danner avatar
2014 GTV300; 2009 S50
@lars_danner avatar
Step 1...
Step 2...
Step 1
Step 1
⚠️ Last edited by Lars_Danner on UTC; edited 5 times
@mike_holland avatar
GTS300 Super 2023 Beige
That job normally took me three days. One to get the engine out and on my workbench, one to swap cylinders/heads, and one to re-assemble.
You will love it. It will give you slightly more power than an HPE model.
2019 GTS 300 HPE SuperTech 72,000km
what's the small pod filter?
@lars_danner avatar
@lars_danner avatar
Breather outlet.
Lars_Danner wrote:
Breather outlet.
guessed as much.
I've considered changing the standard breather on my which goes into my airbox and makes a mess of the paper air filter.
so does it normally live there where if it had a lot if would dribble over the crank case and cylinder? how is it to periodically get at and clean?
@lars_danner avatar
@lars_danner avatar
SteelBytes wrote:
guessed as much.
The hose is normally to the side of the engine so any oil just drops to the ground--no cleaning to do.
[ Time: 0.0093s ][ Queries: 4 (0.0020s) ][ live ][ 334 ][ ThingOne ]
