lx150
lx150
Trying to find Skf or timken numbers for the two needle bearings for suspension arm pin. Similar to HK 20 16 but must be a different size. I am trying to find locally due to time factor. I am also looking for the is the size or part number cross reference for the two seals that go with the bearings. 2007 lx 150 vespa.
@juan_orhea avatar
S150 '09, Beo 500ie '08
@juan_orhea avatar
Is it 16x22x14mm?
https://www.scooter-center.com/en/needle-roller-bearing-piaggio-bk-1614-16x22x14mm-used-for-fork/fork-link-vespa-px-1982-t5-125cc-cosa-pk-gilera-fuoco-piaggio-hexagon-mp3-sfera-skr-quartz-zip-sp-vespa-et2-et4-gt125-gtl-gts125-gtv-lx-lxv-s-1137146
Some bearings are easy to cross-reference…with that crenellated washer, this doesn't look like one of them. Not all Piaggio parts from all suppliers take a long time to arrive.
lx150
lx150
Thanks Jaun
After looking at them closely, I realized the locks were part of the bearing. I will just order them from a Vespa source.
[ Time: 0.0078s ][ Queries: 3 (0.0018s) ][ live ][ 335 ][ ThingOne ]
