Piaggio MP3 500
Piaggio MP3 500
Hi All
just joined this great forum, my name is Dan and i own a Piaggio MP3 500, wondering if i could get some help from the experts here
had this problem today where the ingition barrel is loose and wont turn off, im guessing ill need a new barrel, is it easy to remove does anyone know?, thanks in advance
See video
https://youtube.com/shorts/qILthCaxj64
Dan
mp3 500
mp3 500
if my memory serves me correctly the bezel around the key turns to unlock. there are two small holes or indentations opposite each other that are to facilitate turning. Me thinks to remove it you turn it anti-clockwise.
part #652624, and yes it is easy to break.
Piaggio MP3 500
Piaggio MP3 500
Thanks Scott
Will I need to dismantle the panels to get to the ignition barrel itself?, I think thats what is broken?
mp3 500
mp3 500
To get that specific part ( the collar) off I don't think anything else has to come off but if any other part of the switch needs attention then yes more plastic has to be removed, it's not hard but there lots of screws and it is a pain. I have removed all that stuff twice and it's no fun. Facepalm emoticon
mp3 500
mp3 500
Some of the screws are made to be screwed into plastic and some into those bent metal spring nuts and they strip real easy. So if you do have to do it I suggest take lots of pictures to help in putting it all back together correctly. I used a cupcake pan to keep parts separate. Maybe other members could chime in and add some pointers to aid in this process. I don't know if this link will help- https://www.af1racing.com/ProdImages/st3/ETRS000US4.pdf
Piaggio MP3 500
Piaggio MP3 500
Thanks for coming back guys, mananged to get it out, millions of screws, its the actual barrel itself thats broken, see below and video
https://youtube.com/shorts/bvswDdt4ntM
i guess you can only buy the part as a whole and not change the individual parts inside it
Bike
Bike
Ignition Lock
Ignition Lock
mp3 500
mp3 500
Fun!
Piaggio MP3 500
Piaggio MP3 500
Ah got the new ignition on, but as I was putting it back together the hand brake cable snapped can you believe it, this bike is poor quality to say the least
Anyone got any ideas on how to botch this together I was thinking a connector block to join it but would need a new piece to go into the slot
I'd replace it. It's not that fiddly - getting the plastic off that you've already done was the worst part when I did it way back when! When it's off I bet you find the old outer has cracked and started to rust somewhere near the back.
Piaggio MP3 500
Piaggio MP3 500
Thanks man
Do I have to take more plastic off to get the handbrake cable all the way through the body, ah I'm drained I tell you 😂 😵😵😵
dannyw13 wrote:
Thanks man
I presume you started at the back to remove the plastic - this should give you enough eyeball clues to pull the new cable through with the old. The only gotcha will be if and when the old one has been hard clamped with a zip-tie or whatever.
Piaggio MP3 500
Piaggio MP3 500
Got it thanks, I'm going to try the simple fix of a end wire repair bit where you screw it down, see if that works
If you can find some of those crimps for wire rope you might get away with that. I don't think chocolate block will last very long - but you could try that. Cut the plastic off.
https://www.amazon.com/Ferrule-200PCS-Aluminum-Crimping-Sleeve/dp/B077P4GYBX
2015 MP3 500 ie Business
Replace the cable with a new one. Anything else is a band aid fix.
The cable broke because it is binding.
Piaggio MP3 500
Piaggio MP3 500
Thanks for coming back, yeah I will replace the cable, not too expensive, waiting for the part to come and I'll fit it
Thanks for the help guys
[ Time: 0.0112s ][ Queries: 4 (0.0040s) ][ live ][ 343 ][ ThingOne ]
