Lml star 200
Lml star 200
Good day everyone, I have an lml str 200 with Michelin s1 3.50-10 installed.
Planning on changing to city grips but sizes available are 90/90 10 and 100/90 10.
Any advice on which tire size to get?
Thank you
Gilbert
@starreem avatar
@starreem avatar
Welcome to MV.
You might ask a Mod to move this thread to the NSM section. You will get more timely responses there.
That said, 100/90 is slightly wider than the 90/90, so you won't experience much upgear effect like you would with a taller tire.
@sdjohn avatar
Johnny Two Tone
Johnny Two Tone
@sdjohn avatar
90/90 is shorter overall, closer to a 3x10 instead of a 3.5x10. I used a set of them on my P200 when I wanted to decide about lowering gearing for hills.
the 100/90 is closer to a 3.5x10 if you are happy with the gearing.
Lml star 200
Lml star 200
Thank you for the replies.
I saw a px200 with 100/90-10s installed and it got a bit taller. Will there be problems on the rear? Will it hit any parts of the scooter?
@108 avatar
V range 50s
@108 avatar
V range 50s
100/90-10 is fine, ran it for years before swapping out to 100/80-10 which I prefer the look of.
@rallygeek avatar
@rallygeek avatar
Another option for you to consider is a set of Pirelli Angel Scooter tyres. They come in 3.0 x 10 and also 3.5 x 10 and have a similar modern tread pattern to the city grips.
I have bought them for my rally and et3.
https://www.sip-scootershop.com/en/product/tyre-pirelli-angel-scooter-110-70-12-47p-tl-front-or-rear_80391500
3.5 x 10 installed on std rims
@roland87 avatar
@roland87 avatar
Great tip! Absolutely great tyre!
You have LML 200 four stroke, right? Be ready that 100/90 may rub on clutch cover studs/nuts and on exhaust.
On my LML I grinded down clutch cover studs/nuts and put few washers between exhaust bracket and crankcase to move pipe towards from tyre.
@az_slynch avatar
@az_slynch avatar
Seconded. They're very good all 'rounders for the price. I run them on most of my scoots.
[ Time: 0.0143s ][ Queries: 4 (0.0040s) ][ live ][ 343 ][ ThingOne ]
