Have been working on a custom seat/tank for my Rally 200.
After a bit of playing around have come up with a mockup in card that should be a great starting point and when upholstered shouldn't look too different from the original Super Corsa seat.
I chose this as the starting point as love the shape of the seat (especially as I'm taller) and the "hump" at the rear gives a good spot for the fillcap.
With upholstery will be a little taller than the original - aiming for an extra 10 litres of capacity.
Have added a 1.5cm high step and angled the rim of the seat at the front for air intake through the frame - and another at the rear so a standard rear rack can be used.
This is 14cm wide - hopefully this is enough - haha
Other than this have tried keeping the construction as simple as possible with flat sheet rather than curves - am expecting once upholstered these edges will be softened.
I've created a 2cm lip around the bottom edge to attach the upholstery and so the seat blends in with the profile of the scooter etc - might add barbs/hooks underneath to attach the upholstery.
To attach to the scooter will have lasercut brackets that bolt to the standard mounting points front and rear, these will be accessible from the front and rear stepped sections.
The mount points on the seat/tank will be designed to be modified etc if needed rather than into the main tank body.
Would love any thoughts or feedback - or if there is anything obvious I've overlooked.
