02 vespa et4
02 vespa et4
Rear brakes squeak… it's annoying, brakes work though
did you clean them really good with brake cleaner and clean the rotor?
did you install the anti squeal shims?
finally did you bed them in?
@abner_bjorn avatar
@abner_bjorn avatar
Where do the anti squeal shims go on drum brakes?
02 vespa et4
02 vespa et4
No to brake cleaner. Anti squeal shims or bed is confusion - please elaborate
did not realize your scooter is old and has drum style brakes. so please discard the shim thoughts
@bluecloud avatar
2018 GTS Super
@bluecloud avatar
2018 GTS Super
How did the friction surface in the wheel look? Did you at least hit it with some sandpaper to break any glaze?
[ Time: 0.0090s ][ Queries: 3 (0.0024s) ][ live ][ 343 ][ ThingOne ]
