@peorialx avatar
GTV300, LX150
@peorialx avatar
GTV300, LX150
Does anyone now anything about the OBDSTAR iScan Vespa diagnostic tool?
I assume functionality depends on (and varies with) Vespa model and model year but, while they suggest 'checking the supported list before buying', they do not appear to provide such a list.
I have reached out to them via email and will update this post if/when I receive an answer.
@dariusz avatar
2007 MP3 250ie / 2022 MP3 500HPE SA
@dariusz avatar
I have one, the Piaggio group version (Vespa, Piaggio, aprillia, etc) and can say that works very good.
Inclusive yesterday I have the opportunity to compare with the Texa (Texa cost 3 times more) and have more functionality. In example the Texa can't calibrate the reverse solenoid for the >2019 MP3 500 but the IScan can
@peorialx avatar
GTV300, LX150
@peorialx avatar
GTV300, LX150
Thanks. Appreciate the feedback.
Not familiar with MP3s. Is this a scooter with ODB or pre-OBD? Asking because I am considering it for a 2017 Vespa GTV300 (which is pre-OBD).
@salyzyn avatar
Elettrica 45mph
@salyzyn avatar
Elettrica 45mph
Will it work on a '24 Elettrica I ask?
PeoriaLX if they respond to you, can you tell me which way you communicated with them so I can ask this follow-up question.
dariusz did your (happenstance?) testing only happen on ICE variants?
@dariusz avatar
@dariusz avatar
Mine MP3 is Aprilia type connector, OBD, not OBD2 (this is what I think you ask saying pre-OBD or OBD). But the iScan comes with both connectors if you need them
@dariusz avatar
@dariusz avatar
I open the diagnostic software and I can't find the Vespa Elettrica in the possible options, not sure if I can't find or don't exist. Maybe for Elettrica is needed a special diagnostic tool from Piaggio only Facepalm emoticon and yes, I only use it in normal IC engines
Is not bad idea ask directly to OBDSTAR?
@peorialx avatar
GTV300, LX150
@peorialx avatar
GTV300, LX150
Thank you.
Not sure yet what protocol my 2017 GTV uses. So far I just know it has the flat 3 pin diagnostic connector shown in the pic. Is this the same as on your MP3?
Thanks for the clarification. Yes, I should have said OBD vs OBD2 instead of OBD vs pre-OBD.
I have not heard back from OBDSTAR yet.
2019 GTS300 Supertech E3 61,000km
DIY Diagnostic tool for injection Vespa's with MIU ECU
@peorialx avatar
GTV300, LX150
@peorialx avatar
GTV300, LX150
try a generic OBD2 reader. For understanding Elettrica engine codes see pages 191-194 in https://manuals.wotmeworry.org.uk/Vespa/Elettrica/Vespa%20Elettrica%20EU-USA%20%282018-%29.pdf
@dariusz avatar
@dariusz avatar
PeoriaLX wrote:
Thank you.
Is exactly the same connector and the protocol is standard
@salyzyn avatar
Elettrica 45mph
@salyzyn avatar
Elettrica 45mph
Thanks, I will try.
My 'ol trusty generic OBD2 reader is at my child's house so will be a little while and I will need to purchase an OBD2 to Vespa 6-pin adapter cable (from aliexpress).
I have the 2024- Elettrica service manual and it is more extensive than the 2018 manual, but notably does not list any trouble codes, instead requiring the $1K+ diagnostic tool and companion licensed Windoze software from Piaggio to interpret the codes. Right to repair is kinda borken at this point with Piaggio.
Can you share it?
@peorialx avatar
GTV300, LX150
@peorialx avatar
GTV300, LX150
I received a response from OBDSTAR today. It is brief but includes an attached Excel file with models and years. I there a way I can upload this file here somehow?
@salyzyn avatar
Elettrica 45mph
@salyzyn avatar
Elettrica 45mph
SteelBytes wrote:
Can you share it?
It is 378MB, well beyond the upload quota of 40MB, so not via this venue. Sharing with Google Drive ATM, on a one-by-one basis, I expect one to provide a verified account on modernvespa as key in the share-request email that is generated when you click on the following link to access the document or I will move it to my spam folder. I will probably turn around the share request within 24 hours. There are precious few that own a Elettrica here, so I do not expect a flood ...
VESPA PRIMAVERA TECH ELETTRICA (2024-)_en.pdf
https://drive.google.com/file/d/1HCjPdHxJ3plhqgMt_S_Yb3FXcioil8QE/view
And no, I do not know how to upload to the modernvespa platform in any case ...
You can email it to me, and I will upload it to our manuals archive.
@peorialx avatar
GTV300, LX150
@peorialx avatar
GTV300, LX150
Done.....
PeoriaLX wrote:
Done.....
Thanks, now at:
https://manuals.wotmeworry.org.uk/OBDstar/
[ Time: 0.0133s ][ Queries: 4 (0.0066s) ][ live ][ 313 ][ ThingOne ]
