Greetings all
Here is the scenario. I have a 2003 ET2 where it started to die on me. It never dies when I'm scooting around the neighborhood where there's a lot of start / stops going on. It will only die on the straight runs where I go around 35-40mph.
What do I mean "it dies"? Well, it will act like I flipped the kill switch. Sometimes I can tell when it's about to happen where I can hear and feel the engine starting to cut out and then it's done and it coasts to a stop along the side of the road. Starter turns over fine and strong. It never fires again unless some time has passed.
Here is where it starts to get weird. I've brought a spare spark plug along afterwards. When it dies, I pull the plug cap, plug in the spare, check for spark, yup there's spark, and then when I plug the cap back onto the ET2 plug, it starts up! I can do this every time it dies. It also doesn't seem to matter if I drive it around the block several times where the engine gets nice and warm, then take it on the straight away or if I go straight from my garage cold and do the straight away right away. It will always die in the higher speeds. Pull the plug cap, check for spark, plug it back in, I'm then able to drive back home.
This felt like an electrical issue. Here is what I've replace and nothing I've done seemed to make a difference.
Replaced the spark plug
Replaced the spark plug cap
Replaced the CDI
Replaced the Stator
I've also disconnected the CDI lead that goes up to the ignition switch to bypass possible switch issues. It runs just fine without that plugged in, but the symptom is still the same.
Now for some more details about my ET2
I'm the original owner. It now has close to 25,000 miles. I have never replaced the rings or done a top end job on it. When I test the compression, it's @ 90psi cold. I understand this is low and also unusual for this model to go this long without this type of work done. I will order the needed kit to address the low compression. However, what I described above, would the low compression result in what I'm experiencing? If it wasn't for the whole spark plug test I do to get it to work again, I can understand that being the case.
Thanks for your thoughts….
