JohnDon wrote:
Haha I meant performance wise. Everyone wants performance AND reliability. I was just curious about straight performance. Im well aware maintenance and riding style are prominent factors in reliability, just curious what people would do to a stella motor for "shit yourself fast" at the expense of any sort of reliability.
First thing to remember is that there's nothing slower than a non-running bike. I (and, I think, most other serious builders on here) aren't going to let that caveat go.
If you want REALLY REALLY fast, sell the largeframe and buy a Smallframe. build a Quattrini M200S, which also requires Quattrini cases, crank, and exhaust. Spend another $2k on gears, clutch, carb, VForce reed, etc. and you have a 100+MPH bike that puts out 44 HP at peak and all you have to do it not screw up the build.
If that seems a little wild, Quattrini also make the M1L60S. You can fit it to stock Smallframe cases if you don't mind doing some machining and get 33-35 HP and, again, go over 100 MPH if that's your jam.
Either of those motors are more power than you really want for riding around on the streets. They're loud AF to the point you want earplugs when riding them and you'll feel like an asshole riding them around town after a while. Plus, they have a bad tendency to try and wheelie up and over on top of you when you hit the power band if you're not careful or not experienced with motors like that.
BUT... assume we're starting from Stella cases, so naturally reeded 150cc.
I'm going to number this list for ease of reference and so people can chime in as "On #1..." rather than giant quote-posts.
1) 60mm crank. It's longer than stock, gives you an extra 11cc's, but not so much that it starts to create too much mass via the rod. It's also essential when it comes time to work on your port timings without needing a machine shop to start decking parts. If you want wide power band and torque, especially at lower RPM's, get a bell crank to increase crankcase volume. If you're just chasing peak HP in a narrow power band (which is for racers and, honestly, chumps), get a full circle or at least flowed crank.
2) Serious reed block & reeds. I run an MRP block with Moto Tassarini VForce4 reeds. You can choose another block, but the VForce4 is, undisputed, the best reed.
3) 34mm Side draft carb. Pick whichever flavor you're comfortable with. I like Keihin PWK's. Extremely tunable across throttle positions.
4) Vape Sport (variable) ignition. I recently tested variable vs. static on my Lambretta and got an extra 1.5 HP on the ramp of the power curve just making that change.
5) For exhaust, any of the SIP Nordspeed tuned pipes are good options at this point.
6) Top end. We are in a golden age of cylinders right now, to the point that I don't know that I would pick just one.
Neither of my last two builds have been Largeframes, but they have been Quattrini (M1L60S & TV210), as will my next (Quattrini M1XL if SIP and US Customs can ever get over their bitch fight). That'll be direct intake and should produce over 30 HP, ideally something between my Lammy and the Smallie. And quieter than the Smallie, too.
If you want case-inducted, the Quattrini M1X, Malossi 177 MHR, Parmakit, VMC, and BGM are ALL excellent kits. The VMC & BGM are a lower price point, but at this point in the budget, the difference is practically a rounding error.
7) clutch -- You can probably get away with the SIP Supersport (motorcycle/smallie style) clutch. It's allegedly good up to 30 HP. Past that, it gets expensive fast.
7.1) Get a pinion gear clutch arm & plunger. It's a significantly better design and massively lightens the clutch compared to the standard lever arm, but not full-on hydraulic clutch crazy.
8) Gears. Assume you're going to want to run 23/65 clutch/primary gearing, so you're going to need a new primary drive gear or just buy a whole new Xmas tree. Crimaz or other super-hard cruciform. And eventually, you're going to want to change up your gear stack, but you can't do that until you have some actual data on motor performance, but figure another $500 or so worth of loose gears as you work out exact gear ratios.
That's all just a parts inventory with minimal rationale.
Putting it all together is where the magic happens. Depending on who's doing the work and the trade-offs you make in the setup, the result of all that will be anywhere from 15HP all the way up to 30+, especially if you're willing to give up a little bit at the peak to widen the power band.
And NONE of that has to be unreliable. Especially if you're willing to forgo "cheap" in the name of "good" and "fast."
It just may need serious attention every thousand miles or less, depending on how you ride it, but that's the price of admission to the big tuning game.
