Hi all, I am trying to jet my new carb, after having several soft seizes while running reasonably hard.
While I believe that the problem was caused the carb bottom being shaped like a banana, after flattening the SI 20/15, I realized the float seal was bad...so I moved onward and upward to a 20/17D, which has on the shelf for quite a while.
I have seen the scooterhelp charts, and also read the very detailed wiki guide on tuning. It seems to me that the scooterhelp chart will only guide me back toward fuel efficiency/lean...and I would like a lower AFR then what I believe that would give me?
The motor is a 2 port, 150. Running stock exhaust (for now).
the wonderful table suggests
a/c - 140
mix - E1
main - 102
idle -42
the 20/17D came with a 160/E4, and a 90mm main. This seems too lean to me?
Am I right in thinking that the main should be a bit bigger? I am going to have to order some parts, so would very much appreciate someone suggesting a conservative (rich-side) range of jets to start with?
I have available:
A/C - 120/140/160
Mixer - E3/E1/E4
Main - 92, 90, 80
Idle - 50,42,40, 52/140
Would the 120/E3 or E1 overcome my small jet sizes and work with the 90 or 92? This is not a speed demon I am looking at here...
Thanks for any advice,
Jeff
