Hey guys, so my et2 starts after a few kicks and holding the throttle all the way, but then dies and pukes fuel out the very top of the carborator,(the black part where im pointing) is this a tuning issue or is the carborator bad or what?
Posts: 5363 Location: Oceanside, CA |
There's a gasket that goes under the black cap. Yours is probably torn/non existent causing air/fuel issues. Order a carb rebuild kit and refresh yours.
Two stroke scooters are definitely finicky when everything is not air tight. |
MJRally wrote: There's a gasket that goes under the black cap. Yours is probably torn/non existent causing air/fuel issues. Order a carb rebuild kit and refresh yours. Two stroke scooters are definitely finicky when everything is not air tight. |
The plastic broke?
Is this a genuine Piaggio carburetor or an eBay generic? What's the status of the rubber manifold the carb plugs into? Cracks? |
It's a ebay one, and there are little cracks on the manifold, this is my first motorcycle of any kind so I didn't really know what to buy. When I bought it the carborator was clogged but when I tried to clean it I broke it so I bought this one and after messing with the tuning I got it to work but then it broke again, this fuel issue is new though
Newride wrote: It's a ebay one, and there are little cracks on the manifold, this is my first motorcycle of any kind so I didn't really know what to buy. When I bought it the carborator was clogged but when I tried to clean it I broke it so I bought this one and after messing with the tuning I got it to work but then it broke again, this fuel issue is new though |
GTS 300ABS, Buddy Kick 125
Posts: 13560 Location: Oregon City, OR |
Use reputable parts from a reputable dealer. ScooterPartsCo is a good choice.
https://scooterpartsco.com/ |
Posts: 23443 Location: Harriman, Tennessee, Tn |
next time when ordering cheap knock off carbs off eBay or temu or ali express makes sure you buy them by the box full, (half dozen)
or you can buy 1 decent one and not worry about it |
old as dirt wrote: next time when ordering cheap knock off carbs off eBay or temu or ali express makes sure you buy them by the box full, (half dozen) or you can buy 1 decent one and not worry about it |
