1976 Vespa 150
Posts: 40 Location: Suburbs of Philadelphia |
Is this brown crap that's all over this carburetor solidified gas, or is it some kind of sealer? I'm cleaning all of it off regardless but I'm curious
Posts: 2134 Location: Ventura, CA |
CommanderChaos wrote: Is this brown crap that's all over this carburetor solidified gas, or is it some kind of sealer? I'm cleaning all of it off regardless but I'm curious |
1976 Vespa 150
Posts: 1195 Location: York, PA (the intellectual center of the universe) |
Remove all of the rubber and plastic bits, soak it in acetone overnight, scrub with a tooth brush, then soap and water in an ultrasonic cleaner then blow out all of the passages with compressed air. Good as new.
Success here and we'll talk about promoting you to Captain Chaos. |
1976 Vespa 150
garncarz wrote: Remove all of the rubber and plastic bits, soak it in acetone overnight, scrub with a tooth brush, then soap and water in an ultrasonic cleaner then blow out all of the passages with compressed air. Good as new. Success here and we'll talk about promoting you to Captain Chaos. I have it soaking in carburetor dip right now. I'll do the ultra sonic cleaner tomorrow when I dump the vinegar out of the gas tank. |
CommanderChaos wrote: I thought a commander was over a captain. I have it soaking in carburetor dip right now. I'll do the ultra sonic cleaner tomorrow when I dump the vinegar out of the gas tank. |
1976 Vespa 150
BajaRob wrote: We might have to demote you to Lieutenant Chaos for that one!😂 |
1976 Vespa 150
I use Hoppes 9 on the brass jets. They look new after a little soak. It's not harsh like the older formula so doesn't harm them. Also use it for fuel injectors at my work.
1976 Vespa 150
BajaRob wrote: I use Hoppes 9 on the brass jets. They look new after a little soak. It's not harsh like the older formula so doesn't harm them. Also use it for fuel injectors at my work. I'm super annoyed that the carb and oil pump base gaskets didn't come with the rebuild kit. |
