I just finished replacing the cables on my LML 2T (Stella). All went OK thanks to a lot of searching on these forums.
I tried to start it for the first time and it took a load of kicks (normally it starts on 1-2 kicks). Finally got it started but it immediately revved like crazy, to the extent that switching off the ignition key wouldn't stop it running. I flipped the fuel off and it died after a few seconds (note to self: pull the HT cable next time!).
On checking the carb slide, it's around a third open when the throttle is completely closed. It seems to me that the new cable is maybe a quarter inch too short. I've checked that the outer is seated correctly at both and carb entry and the nylon thing under the headset.
Brand new complete cable purchased as part of set from SIP:
https://www.sip-scootershop.com/en/product/cable-kit-sip-performance-for-vespa-px80-200-e-lusso_94180900
Any ideas? I really don't want to start threading a whole new cable if at all possible.
