Most of the LED bulbs nowadays I found are quite compact and don't have additional modules, and are pretty close to identical measurements of a regular bulb. The first one I purchased from Auxito though was too wide in the heatsink section to fit through the hole in the headlight housing. The diameter of the regular bulb is 25 mm whereas the one I purchased was 28 mm.
The next one I bought I was impatient and didn't want to wait for the seller to provide me the exact measurements, so I just eyeballed it by making sure the heatsink section isn't much wider than the light section above it and it worked.
The bulb from Zethors doesn't have as many reviews as the first one, but I'm happy with it so far. Hopefully it lasts. There aren't that many sellers that sell a single bulb…
EDIT: I should also add that because the section that plugs into the wiring harness is almost identical to the stock bulb's, I did not have to modify the rubber boot around the harness at all!
I hope this helps someone else. 😃
⚠️ Last edited by Lotus99 on UTC; edited 2 times
