GTS 300 SS, LX150, Stella 150
Posts: 98 Location: Florida |
I've got a 2005 LX 150 that I've owned since new. She turns over but won't start. I replaced the coil wire and plug and still nothing. Tried jiggling the ignition switch and she started up. After replacing the ignition switch with a new one I'm back to square one. Not sure where to go from here but it seems like it's in the ignition somewhere. Can anyone with experience with this issue give me some pointers? Thanks!
Posts: 23107 Location: Harriman, Tennessee, Tn |
Posts: 2836 Location: Raleigh, NC |
Posts: 45633 Location: Pleasant Hill, CA |
If the "Engine stop relay" is dodgy, it will turn over but won't start. Try replacing that - swapping with the headlight relay perhaps.
jimc wrote: If the "Engine stop relay" is dodgy, it will turn over but won't start. Try replacing that - swapping with the headlight relay perhaps. |
starreem wrote: When was the last time it was running? |
cubanroast wrote: I haven't ventured past the coil, plug and ignition switch. It turns over fine but maybe its the relay? |
jimc wrote: As I said...
Once again, our resident Vespa guru, jimc, comes through with the correct diagnosis and repair without visual or touchy-feely of the machinery. We are extremely lucky to have him on our volunteer payroll.
Positive
NightWing wrote: Once again, our resident Vespa guru, jimc, comes through with the correct diagnosis and repair without visual or touchy-feely of the machinery. We are extremely lucky to have him on our volunteer payroll. |
It was merely a matter of looking at the circuit diagram for components that if faulty could cause the symptoms, and in this case there was just the one. QED...
jimc wrote: It was merely a matter of looking at the circuit diagram for components that if faulty could cause the symptoms, and in this case there was just the one. QED...
Yuck! That needs replacing! Battery acid attack.
You can buy 80/90A relays complete with socket on Amazon quite cheaply. You'll have to solder and heatshrink the new wires onto the old ones. However, that won't have been the original culprit, as you say the engine turned over - i.e. the starter relay was still working - amazingly! |
Yeah I'm shocked it was working at all. The closest thing I'm finding on Amazon is a 5 pin but it is 80amp. Guessing I can just use 4 of those pins to make it work?
cubanroast wrote: Yeah I'm shocked it was working at all. The closest thing I'm finding on Amazon is a 5 pin but it is 80amp. Guessing I can just use 4 of those pins to make it work? https://www.amazon.com/dp/B0CNLBW59N Yes, I know the advert incorrectly states it's SPST, when it's actually SPDT.... |
jimc wrote: Yes - just ignore the centre pin. I've used these ones for high current stuff in cars etc: https://www.amazon.com/dp/B0CNLBW59N Yes, I know the advert incorrectly states it's SPST, when it's actually SPDT.... When I swap over to the wires it looks obvious where the 2 larger red wires go. Do you think it matters on the smaller ones? Hoping I don't do any damage. |
cubanroast wrote: Thanks for the link Jim. I ended up finding a 4 pin relay/socket combo very similar to the one you sent. Scooterwest got back to me yesterday and said Piaggio stopped making the socket side which used to be part of the harness. When I swap over to the wires it looks obvious where the 2 larger red wires go. Do you think it matters on the smaller ones? Hoping I don't do any damage. |
jimc wrote: It's not polarity sensitive - so no worries there.
Positive
