Hey! The short story is that I wanted to convert my GT125 vespa to 200cc with the sip kit (cylinder+piston+decompressor). So far so good, changed everything, made sure the timing is correct and valves not touching the piston. Started up and it worked like a charm with ocasional pop which was proably due to small jett in the carburetor. Went for a short drive and when reaching 60km/h there was a loud noise and the result was bent crank shaft and piston in pieces. Now I'm trying understand what went wrong. In my mind three things could have contributed - 1) I didn't let it idle long enough thus not enough oil; 2) engine wasn't warm enough; 3) reved too high.
I would apprechiate your input because I have new engine and getting ready for take two with the conversion
