I'm changing the coolant on my 2009 Piaggio MP3 400 IE and I notice that the coolant is green and as far as I've read this takes pink coolant. I believe that the previous owner when doing maintenance put in the wrong coolant and I'd like to put in the right coolant but I've read that when they mix you could run into some issues.
Should I go ahead and put in the pink coolant or should I go buy some green?
Thinking also maybe several drain and fills with pink coolant should do that job as well.
