02 vespa et4
02 vespa et4
i have a 06 yamaha vino and it feels a lot smoother than my 02 et4. my hands go numb after handling the throttle after 30 minutes. anyone have any advice on making the ride smoother? my suspension also feels every bump, while the vino 06 has much better ride with bumps/etc.
@gtdespatchcourier avatar
GTS 300ie
GTS 300ie
Replace the front shock absorber. That should help.
@rickster333 avatar
2001 ET4 "Mona"
@rickster333 avatar
2001 ET4 "Mona"
Darn right. Maybe the rear shock too. Depending on the age of the tires, maybe time for new. And the air pressure in them set for a better ride?
My throttle hand tends to cramp up (probably squeezing too tightly). When it does I try a different grip.
definitely important.
@not what pressure are you using front and rear?
[ Time: 0.0095s ][ Queries: 3 (0.0018s) ][ live ][ 339 ][ ThingOne ]
