1976 Vespa 150
1976 Vespa 150
I've got this oil-injected 150 sprint with the throttle stuck (intentionally) wide open. When I turn the motor over with an electric drill it seems like I ought to see oil squirting into the carburetor bore. Does that sound right?
I don't see anything that makes me certain it's getting oil.
@orwell84 avatar
@orwell84 avatar
It's really a small dribble. I doubt you'd see it. I take the carb box off, turn it upside down and spin the pump shaft by hand. I think counter clockwise. Clockwise for lml engines. You eventually should see oil start to creep through the trough in the bottom of the carb box.
1976 Vespa 150
1976 Vespa 150
Thanks. I started it and I'm getting smoke out of the exhaust so I'm going to call it good. My concern was that I made the gaskets and wanted to make sure I hadn't blocked the passage, although I was extremely careful.
[ Time: 0.0103s ][ Queries: 3 (0.0029s) ][ live ][ 343 ][ ThingOne ]
