@clampett avatar
@clampett avatar
After watching how to make various DIY throttle locks on YT,
I made this one:
?si=5Ob3bV_3nvzk8ZN5
I wasn't happy with it, thinking I could make it thinner.
So for the past 2 nights, I went to tinkering in the garage and make several variation out of scrap plastic I had. It was getting late and the old back started aching. This would be my last attempt today. I had a old plastic fender from a wrecked Burgman. Stiff but easily cut.
First thought was to just let the long section facing the front be steadied by the brake handle. But it would spin around when not activated.
So, I bent it to fit between the throttle cables. That worked. I used the heat gun to bend it and a small section of the ring portion flared. I didn't notice until I fit it and it stayed locked. Reheated the plastic and flattened it out very smooth.
I cut the center hole so it would fit over the throttle sleeve flange very loose.
Then I tapered the inner edges of the plastic circle so it would wedge between the throttle sleeve and switch housing. I didn't know which I'd prefer, so I did top and bottom so it can be activated by pushing up or down.
Put the grip back on for a test fit
Yep, it's thinner than other variations I've tried.
Final test with everything reassembled.
It works. It's cheap. I made it myself. Tomorrow I'll clean it up so it don't look so dirty.
@clampett avatar
@clampett avatar
As usual, once something is done, another person(s) have improvement suggestions.
Can I make it so there is a push on/off for the thumb? Can I make it so you don't have to reach the thumb over the lever to reach the switches?
Ok, here it is. Once engaged, the ring slides up approx 1/8" (3mm).
new version with push on/off and levers out of the way of switches.
Tapered on bottom so it is push up to engage, push down to disengage
new version with push on/off and levers out of the way of switches. Tapered on bottom so it is push up to engage, push down to disengage
Test fit without grip
Another angle of test fit. See the bottom of the ring is tapered so it will slide easily between the Throttle sleeve and switch housing.
Fit with grip from front
view from rear with grip installed
@clampett avatar
@clampett avatar
New scooters since making this throttle lock. That mean making new throttle locks and reconsidering how I made them. I came up with even simpler version that still looks ok and is not intrusive like the Go Cruise or others that lock on the grip:
[ Time: 0.0090s ][ Queries: 4 (0.0029s) ][ live ][ 343 ][ ThingOne ]
