150 Sprint V / 50s
150 Sprint V / 50s
Hi guys,
I have this knocking on the flywheel, it's normal?
It's a Sprint Veloce, it got seize immediately after rebuilt and I managed to unseize it while running.
By the way I have also a knocking on the rear hub, and I feel it on my thumb on the videowhat do you think it is?
Videos bellow:
https://photos.app.goo.gl/B8AhhPHptsffXLa66
Thank you!
VNB VSC VMA VSX - o9c vbc vmb
rearhub doesn't sound like it is torqued in all the way.
Flywheel? I'm not sure. Can you confirm that i was torqued into spec as well?
IDK... if it is torqued correctly then I am at a loss.
@kowalski avatar
2005 Stellalossi 177 Fe
@kowalski avatar
Flywheel looks like it might be loose on the hub. I had a similar situation earlier this year when 7 of the 8 rivets sheared off. In your case you might be able to get away with just peening the rivets again.
@subetherbass avatar
Sounds completely out of balance!
They DO NOT SHEAR OFF!
Did you lap in the flywheel onto the shaft?
Have you done a run-out test to see if it is spinning round squarely
[ Time: 0.0082s ][ Queries: 3 (0.0029s) ][ live ][ 313 ][ ThingOne ]
