@xussma avatar
GTS 300
@xussma avatar
GTS 300
Hi all,
I got all geared up and ready to ride today just to find out that Harriet wasn't feeling up for it. I could start it up with no issues but when accelerating it kind of tried but then stopped.. and couldn't get it out of that.
I know about a lot of things but motorcycle mechanics is not one of them, so I started googeling things.
First I learnt that the feeling of starting and not going (kind of chocking) is called bog down.
Then I googled a bit more and found and old post in this forum, where they mentioned that maybe the tire pressure was the issue... If the tire pressure is different in front and back tires the ASR kicks in and that's the bogging down thingy... So I went out to check it again and yep, I could feel the back tire was quite soft, then I rotate it a bit and found out this ...
The culprit
The culprit
⚠️ Last edited by xussma on UTC; edited 2 times
@xussma avatar
GTS 300
@xussma avatar
GTS 300
I'm very proud of myself for finding out what the issue was Clap emoticon
Now I just need to find a place to change my back tire 😔
Thanks to all that participated in a post almost 5 years ago. You helped a lot!
⚠️ Last edited by xussma on UTC; edited 1 time
@jkj-fz6 avatar
@jkj-fz6 avatar
Thanks for posting the solution! Clap emoticon
That tire looks no where near worn out, so my suggestion would be to install a tire plug. The wheel stays on the scoot and it won't take much more than 5 minutes to do.
⚠️ Last edited by Tierney on UTC; edited 1 time
@xussma avatar
GTS 300
@xussma avatar
GTS 300
Tierney wrote:
That tire look no where near worn out, so my suggestion would be to install a tire plug. The wheel stays on the scoot and it won't take much more than 5 minutes to do.
Yes, I've been told that there's no need to change it, just patching it up is enough.
So my mission today is buying a repair kit and learning how to do that.
PX 150 and GTS 300 HPE Super Tech
I have used Stop & Go tire repair kits for many years and they have always worked great. They use a mushroom shaped plug. I have never had a leak where I plugged a tire, even with high horsepower and speed riding. They may be bought on Amazon or direct from Stop & Go. You would need a pretty basic kit.
https://www.stopngo.com/
[ Time: 0.0100s ][ Queries: 4 (0.0022s) ][ live ][ 343 ][ ThingOne ]
