My '06 GTS hasn't been ridden a ton this summer. It's spent a lot of time on a trickle charger in the garage. The battery is only a few years old. Voltage at rest is normal and the charging voltage looks good too. All of a sudden the GTS will just cut out completely and the dash will go completely out, nothing at all on the display. If I cycle the key a few times I can get it to restart but I'm not too comfortable riding too far from home until I can figure this out. My initial thoughts were a possible bad ground or perhaps an immobilizer issue? I should add that the last time this happened the trip odometer zeroed out, along with the time and date.
Any thoughts on where to look?
w.
