@thomashsb avatar
1964 v90, 1970 VBC, lots of dumb twist n go toys
@thomashsb avatar
I have no clue how long it'll be before I dig into ye olde v90, I snapped this pic with my Temu endoscope doohickey.
Anyone got ideas on how much additional damage I'll find?
@oopsclunkthud avatar
3:5
Broken ring, or circlip, or small end bearing, or ? (in increasing order of mess)
pull the cylinder and piston, inspect the rotary pad...
if it was a ring or circlip and the shrapnel stayed out of the crank then a top end will do it. otherwise it's new crank time as well.
300gts super sport
300gts super sport
Regrettably if something got past the transfer port then you could be in for barrel scoring too. As said above, open her up expect the worst and be pleased if its just the top end.
Good results on that Temu borescope though👍
@chandlerman avatar
Lucky
131 Days Since Last Explosion
Lucky
@chandlerman avatar
Could also be the big-end bearing. That's what took out my crank a couple months ago.
You need to find whatever has you super-lean and fix that while you're at it, too.
@thomashsb avatar
@thomashsb avatar
What makes you feel it was too lean? Plug came out a nice chocolate shake color.
@chandlerman avatar
Lucky
Lucky
@chandlerman avatar
The piston crown is waaaaaay too light for a healthy motor.
@thomashsb avatar
@thomashsb avatar
Unfortunately it doesn't have that many miles on it, it never went much over 300*F on the CHT gauge.
[ Time: 0.0104s ][ Queries: 4 (0.0020s) ][ live ][ 313 ][ ThingOne ]
