I have a 2013 BV 350 that has an issue. Only after about 15 minutes warm up, it will "skip", that is momentarily lose power near maximum speed. I cannot tell if it is the engine losing power or a slipping transmission.
I have already changed the plug and the plug cap, which caused a similar symptom a few years ago. I have also removed the evap canister thinking it was that.
What should I be trying next? Thanks....Drew
