Piaggio Fly 150
Piaggio Fly 150
I have a 2009 Piaggio Fly 150 with under 400 miles that will not start. It cranks but will not turn over. There is spark at the spark plug, gas is flowing to the carb and the battery is fully charged. I have replaced the carb, the fuel lines, the starter and the bendix and still nothing, it just cranks but never starts. It was driven occasionally but never started reliably. There are no dealers or service providers within a reasonable driving distance from me. Any guidance on what may be the problem would be greatly appreciated. Thank you very much.
@oldschooot avatar
@oldschooot avatar
"Replaced the carb" with....??
Piaggio Fly 150
Piaggio Fly 150
I was told and it appeared to be a OEM NOS carb that was sealed in the original box with Piaggio/Vespa tape. It looked identical to the original and fit exactly as the old one did. Due to the age and nonuse I opted to just replace it hoping it would resolve the issue - it did not. Is there a carb difference or problem I may not be aware of? Later I learned perhaps the bendix was not engaging so I replaced it and the starter while there but this also did not resolve the issue. Very troubling and frustrating. What might you think? Any feedback would be much appreciated.
@jkj-fz6 avatar
@jkj-fz6 avatar
How old is the battery? Have you had it tested?
A battery may appear to be fully charged but not have enough juice to turn the engine over fast enough to start.
Piaggio Fly 150
Piaggio Fly 150
Thanks for the reply. The battery has been and remains connected to a Noco trickle charger that indicates a full charge. When the key is turned to on, all the lights go on and when the ignition button is pressed the starter cranks, but the engine fails to turn over. The battery is not the original and not very old either.
2008 LX50 4T
2008 LX50 4T
This bike has been sitting unused for a long time. It's likely that other items have cracked. In particular, the intake manifold.
Have you sprayed ether into the head, and tried starting it like that?
After attempting to start, pull the plug and see if it is wet or dry
There is a possibility that you have intermittent or low spark, due to faulty CDI
Have you checked the valve clearances?
Piaggio Fly 150
Piaggio Fly 150
Thanks very much for the reply. I'll do as suggested and report back. How do I spray ether into the head? Through the spark plug hole? Thanks again.
@crazycarl avatar
@crazycarl avatar
When you replaced the carb, did you replace all the lines and hoses?
You could have a minor crack somewhere affecting your ability to start it.
Also, be sure to disconnect the EVAP line; your canister might be the culprit as well. I had that exact issue with starting. Once the EVAP line was disconnected, the bike started right up.
Piaggio Fly 150
Piaggio Fly 150
Thank you. Ill check all the lines and hose clamps. Hopefully you are correct.
@dooglas avatar
@dooglas avatar
If I read this correctly - the starter is turning, but you say the engine is not turning over. I presume that was the basis of your attempt to replace the bendix. If this is true, then trying to address spark, valve clearance, operation of the carb, EVAP system, or spraying ether into the air intake are not going to remedy the problem.
Piaggio Fly 150
Piaggio Fly 150
Dooglas: Yes you are correct - the starter is turning but the engine fails to turn over and start. I thought perhaps the bendix was was not engaging so I replaced it. There is spark and when I disconnect the supply line from the carb gas does flow out. If gas is flowing then I assume its not a vacuum issue either. The EVAP system has been removed and I have a new fully charged battery as well. Still not starting.
Remove the inlet from the air filter to the carb. Stick your fingers in the carb to move up the CV slide. Spray a fair amount of instant start (ether) in the carb. If the engine is turning over and you don't get a pop, then it's a spark problem. If it runs for a few seconds and quits, it's a carb problem.
@nightwing avatar
Contributor
2007 LX 150 (memories)
Contributor
@nightwing avatar
Sort of confusing. Normally cranks and turns over are the same thing. Cranking or turning over without starting can be a failure to fire, due to no fuel or no ignition.
@barran avatar
Piaggio, Liberty 150S
@barran avatar
I know this sounds stupid, but it happened to a friend of mine. He tore apart his scooter, and it turned out that he had the kill switch on.
[ Time: 0.0118s ][ Queries: 3 (0.0030s) ][ live ][ 313 ][ ThingOne ]
