Hi Everyone!
I got a 2019 Liberty 150 and I need some help. I purchased it from someone who let it set and didn't treat the gas nor use the right octane. It started hard, ran rough no matter what, and check engine light would pop on. Here's what I've done to it:
- New iridium spark plug (from/per scooterwest)
- New OEM air filter
- Adjusted intake/exhaust valves to 0.004
- cleaned the throttle body
- new battery (and kept unplugged overnight to reset ECU)
- ran fuel cleaner (redline) through system
- removed the fuel injector and ran carb cleaner through it (according to robot's video engaging it with 12v)
I've put about 1K miles on it now. Once the engine is warmed up, it runs like butter. Accelerates good, idles good, etc
But...if the engine is cold (ie - not been run for at least a few hours), it can take 2-4 seconds of starting to get her going and she idles rough. By rough, I mean I can hear small rpm adjustments up and down and it just seems too low of rpms. Once the engine is warm, the idle is stable at a bit higher rpm. Ocassionally it'll stall on the initial idle or the check engine light would come on if I left to idle. Happened all the time before I did everything in my list above, but not it's less frequent. Again, take it down the road for 3-5 min, and it's all good.
Anyone have any ideas? It's not "terrible" but would like to have it idle smooth at start-up and take a little less cranking to start. Thanks for any insights!
