MP3 500 2009
MP3 500 2009
Hi all,
I have a mp3 500 2009, the brake lights are stuck on, checked the fuse, and disabled the parking brake, cant seem to isolate the issue, disabled front and rear brake too, any ideas?
By 'disabled' do you mean disconnected all brake light switches?
MP3 500 2009
MP3 500 2009
I believe so, the switches that screw in with the red nipple thing, took them off and the lights are still on, not that great at this sort of thing so any suggestion would be appreciated, not sure if I mentioned but i topped up the fluid too
MP3 500 2009
MP3 500 2009
are they supposed to be lit up and get brighten when you apply the brake?
So you took the switches off - but did you disconnect them? If they are taken off and still connected - the brake lights will be ON! They are normally closed switches, and have to be pushed in by the brake levers to turn off.
MP3 500 2009
MP3 500 2009
Yah disconnected them too, pulled the pins from both brakes at the lever to
pulled? push the pins IN to deactivate the lights. remember either switch will light up the brake lights so you have to do both at the same time.
I suggest just getting 2 new switches FIRST as they are known to be not reliable and seeing how you have a 250 I know yours are old.
MP3 500 2009
MP3 500 2009
Yeah ordered them also it's a 500
MP3 500 2009
MP3 500 2009
And also replaced them twice. Pushes the pin in too. Thanks for all the advice. Guess I'm on my own on this one
What year? Does it have a foot brake pedal?
MP3 500 2009
MP3 500 2009
2009 no brake pedal
MP3 500 2009
MP3 500 2009
I have ordered 2 new switched from Scooter West should be here within the week, I will replace them and see what happens.
Still thinking its something else, maybe a iffy wire, cause disconnecting both of the switches did nothing.
Apologies if I am not explaining this too well, not that savvy with this sort of thing and these forum are a real help specially as there are no shops in Melbourne FL even will to have a look at it
those switches are the same in all the models.
If the brake lights are still on with both switches completely disconnected, then there's a short somewhere else in the wiring.
MP3 500 2009
MP3 500 2009
Yeah thinking that too, thanks going to be fun to figure out
[ Time: 0.0089s ][ Queries: 3 (0.0020s) ][ live ][ 343 ][ ThingOne ]
