Long time reader, first time poster.
I recently replaced a seized top end on my 1981 P200E. It has 36,000 miles on her odometer.
I was already on the fourth oversize piston (and re-bores), so I opted to get a BGM replacement cylinder kit:
https://scootersoriginali.com/products/vespa-cylinder-kit-200cc-rally-200-p-px200-bgm-original
I also got a new BGM exhaust stub:
https://www.bgm-tuning.com/en/product-category/motor/auspuff/auslasstutzen/
I went ahead and cleaned up and re-used my stock cylinder head
After assembling the piston, rings, wrist pin bearing and wrist pin, circlips, carefully mounting the new cylinder and tightening down the re-used clyinder head, then mounting my BGM BigBox Touring muffler, my black cylinder shroud is all out of alignment.
There are 3 touch points there:
-The 8mm bolt into the top of the shroud near the spark plug
-The lower bolt that also goes through the fan cover
-The sheet metal screw at the top that also goes through the fan cover
I can only attach 1 of the bolts/screws and the others won't line up. Take off one, and try another, now the other two won't line up. The sheet metal screw is the worst; it's lined up horizontally but off by a half inch. Maddening.
Some other information:
When I removed the BGM Touring muffler at the start of this project, there was an extra "tab" on the lower screw that goes through the cylinder shroud and fan cover. This is to mount a spring from the tab to the brackets on the muffler. There was only 1 spring, and it was stretched pretty good.
When I re-installed the BGM Muffler (using the BGM exhaust stub), there is no way the spring can be used. The distance from the hole in the tab to the bracket on the muffler is too close.
I read a rumor that the cylinder shroud for a P200E is different from a PX200E, but can't confirm that.
If I look inside the cylinder shroud I've got, I can see is it made by RMS, and has PX next to their logo.
I have taken the scoot for a 5 mile, low RPM ride around the (25mph) neighborhood and everything sounds good.
I'm hesitant to take the scoot on a real road; there are significant gaps between the fan cover and the cylinder shroud. Seems important all the air from the fan gets pushed through to the cylinder shroud.
Anyone run into this issue before? I've been searching the Modern Vespa web site and doing google searches on and off for a couple of days and don't find a thread for this crazy problem.
Any help greatly appreciated.
