Hello dear participants.
Maybe someone tried it install front crash bar and front trunk (from Vespa) on vespa gts 300 super 2024 on one upper attachment point at the same time?
Is it possible to do this at all?
Maybe someone tried it install front crash bar and front trunk (from Vespa) on vespa gts 300 super 2024 on one upper attachment point at the same time? Is it possible to do this at all? |
It is a video maybe check link directly in youtube
https://youtu.be/BG4GfTjWPQw Dima wrote: If you attached an image, it not visible. |
This is not exactly the rack.
I am interested in the Vespa rack with two bolts. Thanks anyway. |
I have the Vespa rack and have ordered the crash bars. I am told by ScooterWest that both will work at same time. They advised that the upper rack mounting bolt is used for the crash bar and the rack. They suggest crash bar first against the frame, followed by the rack.
I have not received my crash bars as yet, but will advise when installing them if there is a problem. Check the Vespa crash bar video by Robot in his recent video on ScooterWest Youtube. You can see that the crash bar mounts to the upper bolt that passes through the horn housing. |
I just received my Vespa front crash bars. I already have the Vespa front rack - the one with the 2 bolts and the suction cups. Originally, I was told to put the crash bar first - behind the front rack, but when I did this, the upper suction cups did not touch the frame, so I put the rack back as before and the crash bars on the top of the rack. It works fine, but the crash bars need to be stretched a bit to reach the upper bolt that holds the rack. The bolt supplied with the crash bars is long enough to go through the rack and the crash bars, so that is not a problem.
I think it looks okay, and it's plenty sturdy, but I don't think I would do it again. Vespa 2023 GTS 300 with Vespa front rack and crash bars fitted.
So everything is fine. If it is not too much trouble, I would like a side view. Thanks for the answer.
Thank you very much. Very useful information. This is exactly what I will do on my VESPA. I will share the result.
