I cleaned out the area on the front wheel where the speedo gear is located and relubed. The gear has 2 different ends yet the speedo cable seems to work either way. When I pulled it out I'm pretty sure the smaller hole end was facing out but one youtuber I watched said that the larger hole needs to be facing out. So which is it? Does it matter?
Thanks!
